ignition problem
Old Jul 14, 2008 | 05:30 AM
sambuka's Avatar
sambuka is an unknown quantity at this point
Default ignition problem
my blazer acts weird. sometimes when i drive for more then 15 miles or so then park, and try to start again it wont start. it has power, but nothing is being sent to the starter. no clicks, nothing. then i let it cool completely down for an hour or so and it starts right up. it has me baffled and as i am sure you can imagine this is very irritating since i drive it everyday...
Old Jul 14, 2008 | 06:26 AM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: ignition problem
It may be the electronic module that is under the rotor in the dist cap.. take off the cap then the rotor underneath there you`ll see a black plastic piece which unscrews from the housing, there should also be plugs at each end.. try replacing that part..
Old Jul 14, 2008 | 06:31 AM
If the starter isn't turning over, the ignition system (with respect to spark) isn't the problem.
I would look into the battery first, making sure that the connections are tight and corrosion free. Depending on its age, it could be a cracked plate or corrosion just behind the posts inside the battery itself.
Beyond that, it is possible that the ignition switch in the steering column could be at fault.
Old Jul 14, 2008 | 06:34 AM
2002XTREME's Avatar
i only said module because he said if he lets it cool off it starts again,, thats why i was thinking that part.. its overheating...
Brian5792
Oct 24, 2018 11:34 AM
Jim Tunstall
Oct 14, 2009 01:47 PM
stevelknievel
Aug 18, 2007 04:30 PM
Bojib
Jun 21, 2007 12:28 PM
headache
Apr 30, 2006 12:47 PM
