Installing tachometer....
Old Aug 25, 2010 | 11:13 PM
dumptruck1990's Avatar
dumptruck1990 is on a distinguished road
Default Installing tachometer....
1990 K5 5.7 TBI with no stock tachometer installed. I am going to buy an aftermarket one at autozone or checkers or whereever.....But, the question I have is I read that the signal for the tach comes from a lone white wire off of the ignition coil. I looked tonight and found a white wire that leads from the coil and goes no where. The wire has a connector to it, but nothing to plug into and my guess because my truck did not have a stock tachometer?? true? So, is it that simple?? in regards to aftermarket tach...red wire to 12 volt ignition source, white wire to dash lights, ground to ground and i think green to tach signal at that empty white wire off the ignition coil?
Old Aug 26, 2010 | 11:26 AM
83GMC-JIMMY's Avatar
83GMC-JIMMY is on a distinguished road
Default Installing new tach
dumptruck1990, your assumption sounds correct. But if your truck didn’t come stock with a tach, it may not have any dash light for the tach "white wire to dash lights". I’ve attached a schematic for a 1997 CK-truck for your reference, sorry I didn’t have one for your year, but the 1997 schematic does match up with the information you provided. Hope this helps.
File Type: pdf
d3d5
Mar 28, 2011 12:16 PM
stereodesigner
May 28, 2010 03:27 PM
nashs1988
Aug 13, 2009 11:26 PM
Cavalier z24
Mar 5, 2009 03:13 PM
MsRandi
Jul 10, 2006 10:23 AM
