Tachometer?
Old Jul 4, 2009 | 08:17 PM
nashs1988's Avatar
nashs1988 is on a distinguished road
Question Tachometer?
Hey i have a 1988 K5 350 tbi stock Distributor.....can i hook a Tach up to it? and if so were? thanks
Old Jul 5, 2009 | 07:05 PM
bandidolenny's Avatar
Yes, you can... If you bought the tach new it will have instructions on which wire to hook where. Otherwise, you may have to search around on the Internet for your particular tach and a wiring diagram. Your HEI setup may have a spot marked for a tachometer, just look at all the wire terminals at the coil for the one marked "tach".
Old Jul 5, 2009 | 07:09 PM
Not sure if the 88 still has the traditional HEI distributor or if it has the computer controlled variant. If it is the coil on top of the distributor style HEI setup, then there will be a standard spade terminal which is the tach output.
Old Jul 5, 2009 | 07:15 PM
nashs1988's Avatar
Smile
It is the distributor with the remote coil. it has a stray wire with a connector coming out of the coil and its not hooked up so maybe that is it. on the distributor under the cap is a "C+" and on the other side is like gbrt? ill look on the internet for a wiring diagram....thanks for the help guys!!
Old Jul 5, 2009 | 07:24 PM
I believe there should be a two pin connector at the coil that has a white wire and a pink wire. The white wire should be the tach feed.
I can verify with my 90 'burb the next time I am down to my dad's, but I am not sure when that will be.
Old Jul 5, 2009 | 11:06 PM
nashs1988's Avatar
Wink
Yes, that is correct...i hooked my green tach wire to it and hooked up ground and power and it lit up and works like a champ. Thanks
No problem! Glad to help!
Old Jul 13, 2009 | 08:30 PM
bluefulltop1975's Avatar
bluefulltop1975 is on a distinguished road
did big blazers ever come with tachs? i wish i had one
Old Jul 13, 2009 | 09:49 PM
Yes they did. Click on the attached image for one. The option is out there for the deluxe dash.
Old Aug 13, 2009 | 11:26 PM
black_billy06's Avatar
black_billy06 is on a distinguished road
I just installed a tach. in My 90 blazer with a 350. There was a white wire with a connector from the factory just hanging there. I tested the tach before I installed na found that the unused factory wire works just fine for a RPM reading. I have a 90 blazer som Idk if it is the same as a 88, but seems chevy never changes much.
mitfan311
Jun 16, 2010 07:59 PM
argon929
May 29, 2010 01:04 PM
stereodesigner
May 28, 2010 03:27 PM
Cavalier z24
Mar 5, 2009 03:13 PM
MsRandi
Jul 10, 2006 10:23 AM
