instrument cluster
Old Feb 17, 2010 | 09:40 PM
1986blueblazer's Avatar
1986blueblazer is on a distinguished road
Default instrument cluster
the cluster in my blazer has been taken off by previous owner who said id doesnt work i dont wanna put it back in and find out it is truely busted because he has taken all gauges out except spedo i was wondering if there is a way to test w/o putting it back together
Old Feb 18, 2010 | 07:49 AM
With a wiring schematic all you would have to do is test the traces from the connector on the back of the cluster to all of the termination points where the gauges hook in. One thing that all of the K5 trucks have in common is the somewhat crappy contacts used from the flexible circuit board to the gauges. These contact corrode over time and the resistance increases to the point that the gauges are not accurate. The good thing is that everything can be taken apart and cleaned up. You just have to be a bit patient with it. I had to redo a trace on the flexible circuit board in the cluster for my '74. A little solder and a piece of copper and it was done!
Old Feb 18, 2010 | 10:49 AM
so would it be better to fix and put the stock gauges back in or modify it and use aftermarket gauges?
Old Feb 18, 2010 | 11:05 AM
That is entirely up to you. I actually like the layout of the stock cluster.
If you were to go with aftermarket gauges, I would suggest getting a blank gauge panel and doing it all the way.
elementalnature
Mar 24, 2008 05:31 PM
error_401
Mar 17, 2008 06:39 PM
DoubleSprings
Sep 15, 2007 11:20 PM
Russ57
May 14, 2007 01:43 AM
FJ40sRock
Mar 5, 2006 04:48 AM
