k5 vortec conversion
Old Feb 14, 2020 | 10:50 PM
awsumpossum's Avatar
awsumpossum is on a distinguished road
Default k5 vortec conversion
Hey guys! was wondering if anyone on here has ever done a vortec swap on a k5-if you have what kind of parts did you use to do it? what was the best and worst part of your swap? the most difficult part of the swap? was it worth it in the end? and what kind of sensors/subsystems did you decide to keep? which ones did you get rid of? just kinda looking for a brainstorm from people who have done it or are seriously considering it and kinda figuring things out as they go along as I am-looking at doing this on my k5 and trying to figure out what im going to get into and trying to cover all my bases-ive done some research on it for awhile now and was going to rebuild the 350/tbi in mine but I think I have decided to go this route instead. anything you guys can think of on this let it fly I think I might have everything covered except my tuning and my harness work-but the engine is not in the blazer yet. here is what I have so far
fuel tank-I was able to keep my stock fuel tank and got a new sending unit for my k5, then removed the stock pump and installed a later model vortec pump
fuel lines-going with russel -6an fuel lines and adapters from tank to engine-I don't think I need a fuel pressure regulator, my particular 5.3 is regulated at the fuel rail
Dirty dingo engine mounts/brackets
shorty headers off an 11 model camaro (was told these would work without having to notch frame or modify headers)
oil pan will be off a chevy Colorado (was told the stock oil pan would contact crossmember at corners-this pan is supposed to remedy that)
also running the 4l60e that was originally with the 5.3-but using my k5 transfer case
i will not be running egr with this engine
still up in the air with evap system
electric fans/aluminum radiator
also going to get rid of the "unneccesary" circuits from ecu ie-battery temp, coolant level
for gauges i think i am going to run the intellitronix gauges dp6004
but instead of using vss on trans/transfer case-i think i might go with a gps speed sensing unit-but don't know if this is compatible with the intellitronix gauges or not
that is my list so far-if anything i think that will at least get the engine running long enough to see what else i am going to need-any thoughts or suggestions are welcomed-constructive criticism welcome also-thanks
Old Jun 16, 2020 | 09:00 AM
daveca's Avatar
They used Vortecs in "everything" - no reason it wont work. The 4L60 is a computerised transmission so if the computer comes along, OK
If not, I seem to recall someone made a conversion kit for manual shift for drag racing purposes. Need something to shift the solenoids.
Id totally destroyed a 4L60 in a 95 S10 by kicking it down hard to get out in an intersection. One tire grabbed and destroyed the reaction clutch for 1-R - ripped the teeth out of the case.
The rebuilder told me its a known problem and cannot be repaired.
For that reason, Id not use that scrawny transmission. That K5 (I have one of those also) is a Lead Sled - much heavier and more load on the transmission.
If its just for 2WD ordinary driving, maybe.
Jonathan Roberts
Nov 7, 2019 08:21 AM
zs_v8jimmy
Jul 22, 2017 09:33 AM
88BlazerBoy
Engine & Internal
Jul 22, 2014 12:25 PM
big P@ul
Dec 5, 2013 10:53 AM
willmac1211
Feb 14, 2010 07:19 PM
