Knocking Noise
[:@]I am new to this forum. I have a 94 K1500 Full Size Blazer and I got up to go to work one morning and a I heard a knocking noise when I started the truck. When I would speed up to 20 the knocking noise would get faster and faster but after I get over 20 mph then the noise goes away but when I start to slow down again at a stop light or something the knocking noise will come back. Wanted to know if anyone else has had this problem or what I can do in order to get rid of this knocking noise. Thank you for your help
The last time I had a knocking coming from the engine duringthe samesituation I had brass in my oil filter from a connecting rod/ crankshaft spun bearing. Recomend carefully cutting open oil filter to check for metal.
When I drove my blazer, yes the sound went away above 20. What would it hurt to cut open the filter and inspect the element. If there is any metal at least you could start the process of elimination.
litterbug
Feb 3, 2010 04:39 PM
bobbyj42
May 13, 2008 12:45 AM
