lower ball joint bolt spinning
Old Aug 19, 2011 | 12:56 AM
gadyck@hotmail.com's Avatar
gadyck@hotmail.com is on a distinguished road
Default lower ball joint bolt spinning
tech is all new blazers cant get my lower ball joint to torque down... its pressed wtf
Old Aug 19, 2011 | 09:32 PM
abig84's Avatar
Try putting a floor jack under the balljoint and lift the truck up then try again. I wish they'd make those ball joints with a little hex head hole in them. Also make sureits pressed in all the way
Old Aug 21, 2011 | 10:02 PM
its pressed in the housing itself doesnt spin just the bolt comin out..... but i guess i can give it another squezze thnks
Old Aug 23, 2011 | 06:26 PM
abig84's Avatar
yeah sometimes if you jack up on the ball joint area it will put pressure on the ball that is spinning and allow you to tighten the nut... well sometimes anyways
Old Aug 28, 2011 | 09:31 PM
summit high's Avatar
summit high is on a distinguished road
try an air wrench, sometimes that will get it to stop spinning by pulling it faster than you can with a wrench, if it is too loose, the spindle ,may need to be replaced!!!
most of the time they are very hard to get to knock loose so the surface that the tapered part goes into could be wallered, therefore making it imposible to tighten it up !!!
reeladdiction
Oct 24, 2011 06:35 PM
bugsbunny16374
Jul 22, 2010 10:04 AM
Bberry20
Jul 4, 2010 11:26 AM
blazinloud
23
May 31, 2009 04:54 PM
timetoblaze
Apr 17, 2006 12:47 PM
