Manual Hubs Lock By Themselves
Old 04-12-2011 | 08:37 AM
mafiaboy01's Avatar
mafiaboy01 is on a distinguished road
Default Manual Hubs Lock By Themselves
Ok, I have an 87 Blazer with manual locking hubs.
When I drive at high speeds the driver side hubs start to lock. They don't engage but from the free position towards the locked position.
This causes a lot of clicking sounds as it tries to engage but can't.
I've looked inside and everything seems fine, I've also replaced the sprint that should keep everything apart but to no avail.
Any tips would be appreciated.
Old 04-12-2011 | 09:58 PM
abig84's Avatar
i had a similar issue in the past and the problem was i had a set of superwinch hubs. they had this big metal gear that would push out when lock the hub (some hubs use plastic gears) anyways it twisted onto this spring and for some reason it would slowly untwist off of it causing it to make noise. i just bent the spring a little bit so it jammed onto it. thats the only thing i can think of
Greghshepherd@yahoo.com
02-23-2012 01:15 AM
oisinirish
02-14-2011 12:52 PM
nismo_2005
11-10-2010 08:05 AM
pbrubaker12
01-28-2010 09:57 PM
FreeBird
02-21-2008 02:18 PM
Quick Reply: Manual Hubs Lock By Themselves
