my damn hood won't sit flat
Old May 18, 2010 | 09:18 PM
ericthughes's Avatar
ericthughes is on a distinguished road
Default my damn hood won't sit flat
my old hood had a big bend in the middle, so i put this new hood on, and now i am having the same problem with this new hood, minus the taco bend in the middle. it just won't sit flush with the fenders. when i took the old hood off, the hood brackets were super wobbly. when i put the new hood on, the hood holds the brackets more straight, and it just won't sit flush.
it's a 78 blazer. here's some pics
any suggestions for fixes?
i've seen a lot of hoods like this
Last edited by ericthughes; May 18, 2010 at 09:30 PM. Reason: pictures too big, needed to make smaller
Old May 19, 2010 | 06:23 AM
Its your hinges. I would remove them, pop out the spring, then clean them up really well and lubricate all joints. Get it moving nice and smooth. If you have some wobbling joints, you can try to tighten them up by reforming the rivets.
The hinges are what caused the old hood to kink.
Old May 19, 2010 | 08:29 PM
yeh the rivets that connect to the truck are barely hangin on how do you reform the rivets?
Old May 19, 2010 | 08:42 PM
You can try hammering on the end of the rivet head that was originally deformed to fasten everything together.
If that doesn't work, I have seen some people find 1/2" OD, 3/8" ID flanged bushings and used a 3/8" x1" long bolt with a self locking nut to replace the worn bushings connecting the main arms of the hinge to the mount plate.
Old May 19, 2010 | 11:28 PM
Ck1500's Avatar
Ck1500 is on a distinguished road
wow once again i was too late on the reply... Swartlkk has it nailed on the head!!!!!
i have used the bushing/bolt combo on other hoods... and as for re-forming the rivots it can be done.. but the ones i worked on they were non existing... so i had to use the bolt combo!
Ck1500
nick'sblazer42
Oct 18, 2011 05:06 AM
shotnva777
Sep 23, 2011 05:54 AM
sprbld417
Apr 25, 2011 07:28 PM
Deatherage
Dec 6, 2010 11:45 AM
ridgewalker
Jan 15, 2009 08:18 PM
