just turned up t-bare and wount sit even
Old Oct 16, 2011 | 08:36 PM
nick'sblazer42's Avatar
nick'sblazer42 is on a distinguished road
Default just turned up t-bare and wount sit even
could us sum held dont no if i need shokes or what?
Old Oct 16, 2011 | 09:06 PM
NVANZEE's Avatar
you need to adjust one side until its even
Old Oct 16, 2011 | 09:59 PM
Clyde's Avatar
Clyde is on a distinguished road
what?
Old Oct 16, 2011 | 10:35 PM
NVANZEE's Avatar
Originally Posted by Clyde
what?
took me a while to understand it too. I believe it says "could use some help, dont know if i need shocks or what"
Old Oct 16, 2011 | 10:48 PM
xgiovannix12's Avatar
took me a while to read it
i think he cranked his tbars and now the trucks not level
he might have a saggy tbar
Old Oct 17, 2011 | 08:04 AM
how could i fix a saggy tbar
Old Oct 17, 2011 | 09:18 AM
pettyfog's Avatar
I love a good challenge.
Was the truck level before you started. did you count the turns each side.
Did you disconnect one side of the sway bar first? Only need disc. 1 side.
I have no idea where to go from here.. but first thing is I would disconnect the sway bar {be careful!} and then adjust in small increments each side till it sits where you want.
PS: bad shocks {one side} will affect height while driving .. not while sitting. Otherwise you couldnt depress them by hand.
Old Oct 17, 2011 | 01:06 PM
its the lower A-arm 1 sits higher but the truck is level and sway bar is connected
Old Oct 17, 2011 | 06:44 PM
pettyfog's Avatar
I suggest you read my post again and answer those questions and try to understand how sway bars work.
Unless you have {1} a bent frame, OR {2} a bent lower control arm..
In which case.. {1} junk it, {2} get one from a wrecker
To put a point on it.. if you jack up one side's torsion bar, then the other side will also lift because of the sway bar. That is why you disconnect it before the TB lift or drop so that each side is bearing its own weight. When you have the front end height where you want it, THEN you reconnect the sway bar.
Got it?
Old Oct 18, 2011 | 05:06 AM
its all good now
shotnva777
Sep 23, 2011 05:54 AM
Deatherage
Dec 6, 2010 11:45 AM
ericthughes
May 19, 2010 11:28 PM
ridgewalker
Jan 15, 2009 08:18 PM
lennyblazer
Sep 7, 2007 08:02 PM
