no 4x4
Old Dec 28, 2007 | 04:43 PM
punx.inc's Avatar
punx.inc is an unknown quantity at this point
Default no 4x4
i was climbinga hill in the snow, and engaged the four wheel drive, locked in the hubs, and nothing was going to the front. the tranfser case engaged in 4h and 4l at the actual case, but nothing is going to the wheels. the front driveshaft was even spinning crazy as i floored it. can hear hubs engaging, so its not that for sure. and the tranfser was going into gear. so why wont it send power to the front? 86 blazer, 700r4 np208, engine is 350 from a 77 truck. can anyone help me out?
Old Dec 28, 2007 | 04:53 PM
Default RE: no 4x4
If only one hub was actually locking in, it would act as though no power was being sent to the front. Can you have someone watch either of the axle shafts at the steering pivots? This would help you to pin point which one is at fault. You could do this in your driveway with the rear end on jack stands.
Old Dec 28, 2007 | 05:15 PM
punx.inc's Avatar
Default RE: no 4x4
already did it. the front drive shaft wont even spin. its like there isnt anything going to that drive shaft. but likei said, its going into gear at the case, just nothing is coming out of the front.
Old Dec 28, 2007 | 08:07 PM
Default RE: no 4x4
Ok so I'm confused... The transfer case is engaging properly, but the driveshaft between the transfer case and the front axle is not turning? Even with the front hubs engaged?? I guess I thought that the front driveshaft was being powered by the transfer case, but the wheels were not spining...
Old Dec 29, 2007 | 02:11 AM
punx.inc's Avatar
Default RE: no 4x4
iknow, its messed up. but it is engaging. you can feel it shift into the gears. i was thinking maybe the chain was broke or something, i dont know.
Old Dec 29, 2007 | 02:56 AM
Chevy Lover's Avatar
Default RE: no 4x4
If the case is not driving the front shaft, it probably is a broken chain.
Here's a diagram of the np203, scroll down for the exploded diagram.
http://www.offroaders.com/tech/Diagrams/np203.htm
Old Dec 29, 2007 | 03:34 AM
punx.inc's Avatar
Default RE: no 4x4
thanks for the diagram of the 203, but, it has a 208 in it. i just saw that typo in my signature, ill get that fixed.
Old Dec 29, 2007 | 03:47 AM
Default RE: no 4x4
It's still probably the chain.
http://www.drivetrain.com/208transfercasesillust.htm
Manteray
Oct 2, 2011 11:53 AM
razman
Feb 22, 2009 01:57 PM
sfesenko
Nov 30, 2008 08:55 PM
sdm1234
Jan 2, 2008 12:12 AM
tolleyc
Jul 29, 2007 05:57 PM
