Not running correct on all eight cylinder.
Old Aug 29, 2008 | 07:12 AM
iboweb's Avatar
iboweb is an unknown quantity at this point
Default Not running correct on all eight cylinder.
I just bourght myself a Silverado 4x4 K10,from 1987 with 350/750, 5.7 liter petrol.
This is my first American car, so dont kill me for my lack of knogledge ;-)
It has stood stillthe lasttwo years, but started direct when charged battery was connected.
However! i“ve got one issue, it seems/feels like it“s not running correct on all eight cylinder.
Some times it feel good, and sometimes not good.
When im stops for red light and so, it sometimes sounds like it will stall, but it doesnt.
I replaced the sparkplugs and checked for sparks on the plugs.
The sparks seems fine, but the issue is allso mustly when im accelerating, running uphill and in higher speed than 30km/h.
Catalyst is removed.
The car got new gasolintank and pump, and start direct on first or secondturn.
Some times when im holding still, it“s going a little bit up and down in revs.
The exhaust is all new from where the catalyst supposed to be.
There is a little leak between the manifole and the engien.
I“ve just changed the oil and filter today.
Anybody got an idear?
Old Aug 29, 2008 | 08:01 AM
Default RE: Not running correct on all eight cylinder.
*Moving to Fullsize Tech* Please choose the appropriate section for your posts. Lifting Tech has nothing to do with an engine issue.
If you have a vacuum leak, you may want to fix that and see how it affects your engine operation.
Jimmy_Blazer
Feb 11, 2013 03:39 PM
mbar
Nov 10, 2010 02:39 PM
wirespider01
Aug 13, 2007 10:26 PM
bhrconcepts
Suspension Tech
Jan 4, 2007 01:11 AM
mscott03
Suspension Tech
Oct 17, 2006 08:10 PM
