NP203 Only Took 3 Qts
Old May 2, 2014 | 04:17 PM
misweetrevenge's Avatar
misweetrevenge is on a distinguished road
Default NP203 Only Took 3 Qts
So from what I read before I drained my 203, you drain it from one of the 2 bottom bolts on the same side as the fill plug and then it takes 5 quarts to fill to the bottom of the fill hole.
I drained it until it stopped coming out of the bolt hole and started to fill it but it only took 3 quarts and then started flowing out of the fill hole. Am I supposed to drive it a little and then top it off? Or should it take the full 5 right away? Did it drain completely?
Old May 3, 2014 | 08:07 PM
abig84's Avatar
if its full its full. theres really no channels or goofy things inside that wont get oil unless you drive it. i only remember mine taking like 3 or 4. if you want to be paranoid, drive it around for a day and recheck it
Old May 3, 2014 | 08:12 PM
good to know. Thanks.
chiefbong360
Dec 17, 2020 12:53 PM
Razorburn71
18
May 15, 2011 04:52 PM
Dark79K5
Dec 29, 2010 10:38 PM
trickett
Oct 13, 2010 08:31 PM
fouronereason
Sep 7, 2009 10:04 AM
