Oil cooler lines help plz
Old Feb 7, 2013 | 02:00 PM
Williamsb7181's Avatar
Williamsb7181 is on a distinguished road
Default Oil cooler lines help plz
Im trying to stop the oil leak on my 98 blazer 4wd 4.3 and I changed the lines that go into the radiator but didn't help so now I'm trying to change the ones that go to the block but I came across a snag. The bolt on the filter assembly is really easy to get to but how do you get the bolt on the other side of the lines without unbolting a mount and jacking up the enginr a bit? No idea how ths ended up in full size tech sorry my phones tarded
Old Feb 7, 2013 | 02:29 PM
neo71665's Avatar
They put 4.3s in 4x4 tahoes?
Old Feb 7, 2013 | 02:39 PM
richphotos's Avatar
You lost me there.
Old Feb 7, 2013 | 02:44 PM
AKJeff64's Avatar
AKJeff64 is on a distinguished road
Default Oil lines...
To loosen the bolt, you will need a couple of extensions and probably a swivel. Once the bolt is out, it might look like the assembly will be easy to get out, but it won't come out. Grab a block of wood and place it under the oil pan as close to the front as possible and remove the mounting bolt on the driver's side. Once you jack it up a bit you can slide it out and get the new one in. I just did my 98 not too long ago, and I had to do it on my 96, and my Astro van..so speaking from experience..good luck!
Old Feb 7, 2013 | 05:13 PM
Ok thank you cuz I have the gm service manual and all it says is take out the 2 bolts but when I looked at it I just couldn't see how. I will try this tonight and hopefully not have to add oil every week ha.
Old Feb 7, 2013 | 05:35 PM
matt9589's Avatar
matt9589 is on a distinguished road
I got the same blazer with the same issue lol
Old Feb 7, 2013 | 05:53 PM
Blazin00LT's Avatar
Blazin00LT is on a distinguished road
Don't remind me, mine are getting worse.
Old Feb 8, 2013 | 11:58 AM
neo71665's Avatar
You lost me there.
We in the fullsize section and I've never seen a 4.3 in a fullsize suv with 4x4. Matter of fact I've never seen a 4.3 in any fullsize suv, only base trucks.
Old Feb 8, 2013 | 12:46 PM
richphotos's Avatar
ahh touche, I never really look at the section for some reason, I just see the posts, and click LOL
low1
13
Oct 10, 2012 05:50 PM
fslobodecki@yahoo.com
Apr 15, 2011 03:29 PM
subarugt06
Mar 6, 2011 11:21 AM
FlatTopFoley
Dec 23, 2008 12:27 PM
Jetfixer
Jul 11, 2006 05:02 AM
