Please Hlep.. Alternator issue
Old Nov 30, 2010 | 06:42 PM
That is what the schematic says that it is supposed to be hooked to...
Old Nov 30, 2010 | 06:49 PM
Looking at the schematic, it appears that all of the wires should be energized when the ignition switch is on...
Old Nov 30, 2010 | 06:51 PM
buffalorider13's Avatar
buffalorider13 is on a distinguished road
hmm.. i dont understand why it wouldnt get power.. what happens if you hook them backwards?
Old Dec 1, 2010 | 10:35 PM
6.2 man's Avatar
6.2 man is on a distinguished road
The the one that is hot comes off the battery . The other is off the ignition switch to turn on the alterneter. You can run a wire off the battery to check it for charging . I think if you run a wire off your fuse block thats says ignition you will be okay
The hot wire mesures your battery voltage and the other truns on the alternater
Last edited by swartlkk; Dec 1, 2010 at 11:06 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Dec 2, 2010 | 12:36 AM
well why would it smoke if i ran a jumper from the batt stud.. i tried that just to test it out
Old Dec 2, 2010 | 11:33 AM
6.2 man's Avatar
i think you have something wrong with your alternater and thats why there is no juice at the ignition wire . If you can afford it go buy one of those one wire alterneters and not mess around with that little plug .
Old Feb 5, 2011 | 07:43 PM
355sexyjimmy's Avatar
355sexyjimmy is on a distinguished road
im haven the same issue with my 89 jimmy new alt new bat new ground and alt to bat wire all beefer then stock and i have a drain only when running stumped as well
Cassi Davis
Apr 3, 2014 09:53 PM
Matt Barrett
May 8, 2013 09:23 PM
Motocross16
Aug 2, 2011 07:44 PM
jc96blazer
Jul 20, 2010 07:31 PM
DrkJrny
Jan 1, 2009 05:09 PM
