POS 93 Full Size Blazer
Old Aug 12, 2011 | 09:41 PM
ArizonaBushman's Avatar
ArizonaBushman is on a distinguished road
Default POS 93 Full Size Blazer
Been working on this issue for quite sometime now . When the truck starts it idles roughly but will smooth out around 2 grand. When the engine is under load it will not have any power, it spits, and sputters, when I let off the gas it dies. It will go into passing gear but no acceleration or power. It basically falls on its ***.
List of replaced parts replaced:
Tranny serviced (actually rebuilt it)
Fuel Pump
TPS
distributor and internal components (they came with the new distributor)
Timing chain and gears (was slapping the side of the block lol)
Plugs
wires
cap and rotor
Fixing to replace
EGR Valve
MAP sensor
O2 sensor
Vacuum lines
I really have no clue what the issue is with this truck I have worked on trucks for a long time now and never ran into this. It isnt throwing anymore codes at me. I checked the injectors and they are fine too. I am looking into a total new exhaust as well. Any suggestions would be appreciated. I really feel like shooting the thing
Old Aug 12, 2011 | 09:53 PM
TheRandom1's Avatar
You say fuel pump but don't mention a fuel filter. Did you do that?
Old Aug 13, 2011 | 07:01 PM
Yes I did, I apologize for not mentioning that.
Old Aug 14, 2011 | 08:55 AM
abig84's Avatar
Computer or distributor issue? Maybe check the timing and timing advance. I bought a 90 that used to jerk around and constant speed and a mechanic thought It was the trans. Ended up being the computer kept dropping time on me
admathi
Dec 15, 2019 04:24 PM
Romodavid15
Dec 27, 2011 05:37 PM
Dartanian81
Mar 27, 2011 02:35 PM
goerzenl
Nov 1, 2010 10:14 PM
PawNtheSandman
Engine & Internal
23
Aug 27, 2006 11:22 PM
