Power Steering Brackey
Old Mar 9, 2011 | 10:29 PM
bhasby's Avatar
bhasby is on a distinguished road
Default Power Steering Brackey
I recently bought an 84 K5 Blazer. Planning on restoring the body and putting a lift on it.
The rig has a 350 with headers on it. However, when the guy I bought it from put the motor in it, he neglected to put all the brackets on there. Where I believe there was a bracket where the AC used to bolt with the power steering, there is not a piece of mechanics wire holding it in place. Anybody know what bracket I need, and/or where I can find it?
Old Mar 11, 2011 | 07:26 PM
blueblazer1982's Avatar
blueblazer1982 is on a distinguished road
need some pics then i could tell you. i have a 350 in mine as well
Old Apr 27, 2011 | 01:52 PM
86blazin's Avatar
86blazin is on a distinguished road
I don't know if its the same I have a 305 but there are ac beakers u can buy but I havnt found any power steering bracket. This is only if you have headers on it if the exhast manifold is stock then I should bolt on with the exhast manifold. I am in middle of putting headers on mine and it has.been an experience! Hope this helps you!
Old Apr 27, 2011 | 01:59 PM
86blazin's Avatar
Google part number 10042. That is the ac bracket I am getting mine at orielly outo I know auto zone has it also but hi can get it online also. Like I said havnt found a power steering bracket bu I figure if I get a bolt stud and screw it in and then tighten it with a nut then put two nuts together and tighten them together at the hight of your power steering mount then put a nut over that it will work hope you understand that. Its hard to explain.
ctyler
Aug 25, 2020 04:06 PM
litterbug
Oct 19, 2011 07:50 AM
Parilio
Sep 21, 2011 06:56 AM
caseroj
Oct 20, 2010 08:10 AM
1991whiteoutblazer
Jan 8, 2009 08:17 PM
