power steering pump wont fit !
The problem is that the '90 motor came with the factory serpentine belt setup while your '82 had a multiple v-belt setup. There should be the bolt holes you need, however, you may have to remove a stud from the driver side head. The water pump is likely not equiped for the mounting of the pump bracket so you would have to swap that out.
any one know how to remove a power steering pump from a 1990 full size r\v series blazer i have the steering lines off and the bolt in front loose but not out cause i have not removed the pulley yet? how many bolts or any help Thanks..........
1991whiteoutblazer
Jan 8, 2009 08:17 PM
jetsmy
Aug 1, 2008 10:10 PM
irata
Jul 7, 2007 03:36 PM
