problem with transmission while driving
Old Mar 6, 2011 | 08:10 AM
yarinzim's Avatar
yarinzim is on a distinguished road
Default problem with transmission while driving
hello!
blazer k5 1990, 5.7L - while cruising on 90-100kph the transmission seems like it can't decide in which gear it wants to be in.
this "jump" happens several times in each drive, while the gas paddle is in solid position of course. a quick jump between the third and the forth and then it settles down.
any ideas?
Old Mar 6, 2011 | 09:02 AM
Your transmission has a lock-up torque converter. It sounds like that is going in and out of lock up.
Do you have a tachometer? If so, how much does the RPM rise/fall during the event? What RPM are you running if you pull it down into 3rd gear?
Old Mar 6, 2011 | 09:50 AM
yarinzim's Avatar
no tachometer and no rpm gauge of course..
Old Mar 11, 2011 | 07:28 PM
blueblazer1982's Avatar
blueblazer1982 is on a distinguished road
sounds like your 700r4 isn't holding the lock up. there is a way to make a manual switched lock up.
matthewp
Apr 6, 2015 08:57 PM
quinnsjoblom
Apr 9, 2014 08:32 AM
S.Hafsmo
Nov 14, 2013 03:38 PM
eskylar!59
19
Dec 23, 2008 09:13 PM
killerelfboy
Feb 27, 2008 06:58 AM
