Quick Help Needed
Old Jul 8, 2011 | 03:49 PM
brooklynRick's Avatar
brooklynRick is on a distinguished road
Default Quick Help Needed
Trying to take engine apart but stuck on the timing chain cover, I cant get to the big wheel that drives the belts off which is blocking it. Not sure it looks like it should pull off but it wont budge?
Any help thanks
Old Jul 8, 2011 | 04:02 PM
You often need to use a puller to remove the balancer. And not a typical pulley puller as it will damage the balancer. You need one that will bolt on the front of the balancer where the accessory drive pulley mounts and then has a threaded rod in the middle to push the balancer off.
Old Jul 8, 2011 | 05:14 PM
rats...
thanks tho
sleepterror
Nov 28, 2008 06:30 PM
igot10pinitis
Jan 19, 2008 10:42 PM
Zasder
Dec 13, 2007 07:54 PM
blazinwoody
Engine & Internal
Jan 11, 2007 05:30 PM
strongboy2005
Feb 3, 2006 10:07 PM
