Removing '82 K5 T-Case
Old Dec 20, 2009 | 11:49 PM
1982blazed's Avatar
1982blazed is on a distinguished road
Default Removing '82 K5 T-Case
Hey guys, I need to take the T-Case out of my '82 K5. Its a 350/TH350 with an NP208 case. I was wondering if anyone could list the steps to take it out? and also, What do I do after I get it out to identify if I can bolt up a NP205 without any modifications(if thats possible)? Thanks.
Old Dec 21, 2009 | 03:12 PM
abig84's Avatar
JUst disconnect the driveshafts. Dissconnect the shifter linkage on pass side. Should be a type of cotter pin in there. Disconnect the vent line if you have one and electrical connection. Drain fluid. Unbolt the transfercase from trans and lower down with a jack. Pretty straight forward
Old Dec 22, 2009 | 09:50 AM
1982blazed's Avatar
Yea that is, Thanks alot. When I un-bolt the cross-member holding the case up, do I have to support the tranny? or will it be fine?
Old Dec 22, 2009 | 10:23 AM
You will need to support the transmission if you take out the crossmember.
Old Dec 23, 2009 | 09:50 AM
1982blazed's Avatar
Ok cool. Thanks guys, that is all. I will get on that in the next few days or so. I don't know how to delete threads but if someone does, they can delete this one if they want . Thanks again.
Old Dec 23, 2009 | 01:38 PM
abig84's Avatar
You dont have to remove the crossmember. The crossmember supports the trans and adapter. The Tcase bolts to the adapter. You just have to move the case back like a 1/2 inch backwards to clear the crossmember. I always leave it but if your doing this with crappy jacks then might as well take it out to be paranoid
Old Dec 23, 2009 | 03:34 PM
1982blazed's Avatar
Oh yea thats true. Haven't been under there in awhile but I remember now changing the spacers under the adapter which was connected to the cross member. Thanks!.
Old Dec 28, 2009 | 05:28 PM
1982blazed's Avatar
got it out in about 3 hours...
Old Feb 4, 2010 | 07:13 AM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
the 205 is going to have an adaptor between where it bolts,
Flyfishen
Jun 18, 2019 11:22 AM
bensaintonge
Dec 3, 2013 08:14 AM
bam_9_9_9
Jun 1, 2009 03:50 PM
mlprus
Feb 14, 2009 07:02 PM
sunnyc123abc
Sep 9, 2004 04:59 AM
