Replacement Fuel Tank Question
Old Feb 14, 2011 | 08:03 AM
Nick_K5_Blazer's Avatar
Nick_K5_Blazer is on a distinguished road
Default Replacement Fuel Tank Question
Hello all,
Nick here. A few weeks ago I started a thread about changing the fuel tank in a K5 I was looking at buying. Well I bought the truck and all of your suggestions really helped in getting it out. I did not have to cut an access hole in the floor as one suggested which was a relief. Now I have a question about the ground wire. The old tank had the ground wire welded on to the tank (at least I assume it was welded). The new tank (which looks identical) does not have a specific area like the last one where the ground should go. Will a ground connector work or should i solder/weld the wire on there like the old one?? Thanks for any help one might provide!
Old Feb 14, 2011 | 12:40 PM
abig84's Avatar
i would think it should have came with the wire attached... i had one break off on me before and i just self tapped a screw into a thick area of it and itworked fine
Old Feb 14, 2011 | 12:44 PM
BigBlockBlazer's Avatar
BigBlockBlazer is on a distinguished road
Anywhere you can hook a ground strap to will work.
Old Feb 14, 2011 | 02:13 PM
Will look into both ideas...thanks guys!
Old Aug 19, 2011 | 01:27 AM
gadyck@hotmail.com's Avatar
gadyck@hotmail.com is on a distinguished road
mine was thread bolted into the nearest cross member
Smc
Nov 14, 2013 04:46 PM
pollocksa
Feb 4, 2012 09:12 PM
wjdjake
Jul 17, 2011 02:06 AM
Hank3band
Jun 6, 2011 06:44 PM
PhiL4x4
Nov 16, 2009 04:05 PM
