Rim swap question s10-k5
Old Jan 30, 2010 | 08:54 AM
blazin8556's Avatar
blazin8556 is an unknown quantity at this point
ok. makes sense then...:]
Old Jan 30, 2010 | 09:18 AM
And just to close the loop here, even tirerack could be used to determine bolt patterns used. Simply put in your truck and see what rims pop up, but that goes back to knowing what you have...
All S-series have a 5 bolt on a 4.75" bolt pattern.
The 1/2ton 4wd SFA K5's (67-91) have a 6 on 5.5". The military version 3/4ton and 1ton K5 came with an 8 on 6" pattern.
The 2wd K5's (67-91) have a 5 on 5" pattern.
The IFS 1/2ton and 3/4 ton pickups used the same 6 on 5" pattern, but the hub diameter was reduced for the unitized hub/bearing assembly which means that the newer rims will not fit on the older SFA trucks without opening up the rim. This can be unsafe if done incorrectly so find someone that knows what they are doing before considering purchasing the newer rims.
Old Jan 30, 2010 | 01:20 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
wouldn't a 4wd 1500 from those years you gave me fit without drilling. cause didn't they also have lockouts for the hubs. or were they smaller in diameter? (when i say smaller in diameter i mean the opening the rim allows for the lockouts to pass through)
Old Jan 31, 2010 | 01:10 PM
Read much? IFS = Independent Front Suspension. Those would be the ones without the lockouts... Come on... Keep up already.
Old Jan 31, 2010 | 01:14 PM
Banned
sorry, thanks for clarifying kyle
evuldrporkchop
Mar 4, 2013 01:20 AM
rta60460
Apr 28, 2012 12:58 PM
blazinloud
Tires and Wheels
Jul 9, 2008 11:19 PM
magtec
Apr 26, 2006 11:09 AM
