shakes side to side when braking need help
im new to this forum so please bear with me. I have a 1984 K5 last month is when the shaking from side to side began and it only happened when i would brake and it wouldnt stop until the truck came to a complete stop. i asked around and took it to a places and they all said it was the spindle knuckle so i replaced it. two weeks go by and now its doing it again but even worse. no one seems to know whats causing the problem. if anyone has any advise i would appreciate it
Are your brakes bad? Mine are and it shakes/vibrates pretty bad esp when I'm getting off the highway.
And.. did he show you the spindle knuckle when he told you it was bad? The only knuckle I can think of spindle wise is the steering knuckle that everything bolts to. And that's a huge hunk of metal. Don't see why that could cause shaking unless it was cracked...
yeah the spindle knuckle was bad the part where you screw everything onto was cracked. The brakes are about a month old. im taking into the dealership that my uncle bought it from and see what they can tell me
Ah, um.. there has to be more to it than just the knuckle being bad. It is solid metal after all. Bearing maybe? Def. get a second opinion
*moved to 'full size k5 tech'. The 'new member' section is not for asking technical questions*
Sounds like 'death wobble'. How are your steering components? Nice and tight side to side? Do you have larger than stock tires on it? Lift?
that was right inline of my first thoughts.
and Kyle is probably the best member on here to ask about these K5's, jesse.
i'd definately be looking @ the front end of that truck.
no the steering is pretty loose and my tires are 32x11.5 15
thanks ill look into it i appreciate yalls advice ill keep yall updated on the progress
trippymg
02-17-2012 08:10 PM
IronMan
09-21-2011 11:28 PM
shmew22
09-08-2009 08:18 PM
Charidy
08-06-2005 06:33 PM
