Some addvise
Old Feb 28, 2013 | 02:04 PM
wesK5's Avatar
wesK5 is on a distinguished road
Default Some addvise
im starting a new build and im not sure abiut up grades so i could really use some advise im building a 350 4bolt main board 30 over and im woundering what intake and throttle body to go with for the best power but also good for driving down the road. any advice would be appreciated .
Old Feb 28, 2013 | 03:48 PM
Twip's Avatar
edelbrock should make some stuff for a 350 that should just bold on. unless you are going to be buying a stand alone fuel injection system, you could always go carburetors.
Edelbrock Performance Parts and Accessories - Home
Old Mar 18, 2013 | 05:57 AM
wesK5's Avatar
Default quetion
I hae an 89 k5 and im woundering which is better a dana 44 front axel or the corporate that came with it. itis on 35 but it is daily driver also m also runing 3:73 gearz
Old Mar 18, 2013 | 05:52 PM
70-K5's Avatar
70-K5 is on a distinguished road
The D44 and the 10-bolt are very similar in strength and construction. If they are both in the same condition then there is no reason to swap them.
As far as the engine question goes, are you keeping your fuel injection? Building an engine that will operate within the parameters of the stock system will be very boring. Unless you have a big chunk of change to drop on a MSD Atomic...
Old Mar 19, 2013 | 01:55 PM
wesK5's Avatar
ok thank you
88s10Blazer
Lifting Tech
34
Oct 17, 2010 02:50 PM
ImScrewed92
May 30, 2010 12:05 PM
davidluzader
Mar 1, 2010 10:25 AM
ZLover4Life
46
Dec 22, 2008 01:01 AM
scottyk
Mar 19, 2007 11:32 PM
