Someone please help me !!! '76 k5 ...
Old Feb 7, 2024 | 05:05 PM
rxkendall's Avatar
rxkendall is on a distinguished road
Exclamation Someone please help me !!! '76 k5 ...
my recently aqquired k5 is on a jack stand on a residential street . the previous owner got in a high speed chase and popped a curb, severing all six studs and sending the rim flying. the truck dropped on the front end . its the four wheel drive , with manual locking hubs . the hub is bent at the mouth. i need desperately one of the follow...
1. to know if i can use the sets from retailers that have the rotors and hub together , not sold seprately but as one piece. (mine comes with the two seperate pieces.
2. need a hub if anyone has one in the phx metro area.
3. a machine shop that will fix the hub safely .
or i just need advice , does n e one have any good ideas on how to best fix my situation???
Old Feb 15, 2024 | 04:39 AM
Welcome to the BlazerForum. I'm moving the thread to the appropriate section.
We have knowledgeable members on K5's. Give it a couple of days to get an answer.
Old Feb 15, 2024 | 07:37 AM
The rotor/hub assembly you are looking for is specific to 4wd models and is a two piece design with the rotor held to the backside of the hub using the wheel studs which get pressed through both pieces. THIS ILLUSTRATION shows you the configuration you are looking for as well as gives you an idea of the year range you can look into for the fullsize GM trucks to get the part you need if you call around to parts yards in your area on your hunt for a new hub. You are looking at any half ton 1973-1977.5 model year GM fullsize 4wd pickups.
As to repairing the hub assembly, if the flange on the hub where the wheel studs press thru is damaged, repair really is not advised. While it is getting more difficult to find these parts failure of a repaired component could prove costly.
If you could post a picture of the damage from a few angles, we can try to point you in the proper direction for what components need to be replaced to get the vehicle back on the road.
Megan Starr Hare
Jul 25, 2020 10:33 AM
chrisdrnr
Jun 7, 2012 08:06 AM
Blazerboy8692
Nov 27, 2011 08:16 PM
HiredDriver
Apr 25, 2010 09:01 AM
EnyChevyUK
Mar 21, 2009 07:55 PM
