Speedometer jumping
Old Jun 24, 2009 | 07:36 AM
snakeboy38jm's Avatar
snakeboy38jm is on a distinguished road
Default Speedometer jumping
I am the proud owner of a 1993 full size chevy blazer 350V8, 4x4, auto My problem is the speedometer is jumping even in park i am doing 70+ MPH. I was told the VSS was the problem but the wrecking yard told me the cluster was the problem and i replaced it with the same results. Also the ABS light has been on for over a year.
Possible solutions
1) ECM ground wire?
2) VSS
3) ???
i had this problem 5 years ago and it corrected itself
also it happened after i jumped a Ford
Old Jun 24, 2009 | 06:33 PM
I would definitely suspect the VSS before the gauge cluster.
Old Jun 25, 2009 | 09:03 AM
I took off the wire to to the VSS sensor and it still had the problem. I have replaced the cluster to no avail. After having a transmission shop put it on the computer he told me the ECU must be bad, Guess what i just bought a new ECU and i still have the problem.
Lets check the score card
1) cluster $75
2) shop service call $80
3) new ECU $119
Knowing never to jump start a Ford Priceless
Old Jun 25, 2009 | 06:00 PM
ECU... Well, I would have suspected the DRAC (Digital Ratio Adapter Controller) module before the ECU as well. It is also possible that you have a wire grounding out somewhere under the truck or under the dash.
Old Jun 25, 2009 | 07:07 PM
mahoney1988's Avatar
mahoney1988 is on a distinguished road
do you have a aftermarket cd player....One time a guy in the town i live in put one in and his speedometer was jumping like that...it finally burnt his alternator up some how.. it does that every time he puts a cd player in it.. its the second time its happened.
whoareyou4
Aug 14, 2009 01:55 PM
BobTheBlazer
Jul 16, 2007 04:18 PM
breezy32784
Jun 29, 2007 12:29 PM
soul_seeker77
Mar 11, 2007 04:41 PM
Hanr3
Mar 2, 2007 11:32 PM
