Stalling Problem
Old 03-17-2009, 08:53 PM
I was not talking about restrictions, just that it may take some time to get all of the air out of the fuel lines. Blowing through them only returned you to square one.
Old 03-18-2009, 04:27 PM
sensesfail85's Avatar
sensesfail85 is an unknown quantity at this point
i dont know if this is important, but after it stalls out there is usually about 1/8 of an inch of fuel that i can see just sitting in the carb
Old 03-18-2009, 08:12 PM
How can you see fuel in the carb?
Old 03-18-2009, 10:11 PM
when i take the air filter off
Old 03-18-2009, 11:54 PM
if there is fuel left in the carb after it stalls does that mean its flooded?
Old 03-19-2009, 09:38 AM
Where is the fuel? On top of the throttle blades? Down inside the intake (you would have to open the throttle blades to see into the intake?
If it is either of these, then your problem is likely a stuck float which is not shutting down the flow of fuel into the fuel bowl on the carb.
Old 03-19-2009, 12:43 PM
it looks like its on top of the throttle blades
Old 03-19-2009, 12:48 PM
That is odd...
Do you know what model carb is on it? Can you take some pictures of the carb?
To be running fine and then not after you ran out of fuel just does not make any sense.
If you can take some pictures that might help identify the carb as well as some pictures showing your concerns about this "1/8 inch of fuel", that would help us out greatly.
Old 03-19-2009, 12:52 PM
how would i fix a stuck float?
Old 03-19-2009, 01:05 PM
http://store.summitracing.com/partde...?part=edl-1407
that is the carb i have, it looked like the 2 jets towards the front of the truck are not shooting any fuel,the rear ones look like they are just pouring out.
Quick Reply: Stalling Problem
