steering wheel issue
Old Feb 10, 2007 | 01:55 AM
thevair65's Avatar
thevair65 is an unknown quantity at this point
Default steering wheel issue
my truck has tilt wheel and it seems the joints that allow it to tilt have warn out.
my question is can i just replace the joints or does the entire steering rod have to be replaced.. if i recall correctly the steering box doesnt come off of the rod?
Old Feb 10, 2007 | 05:39 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: steering wheel issue
If you are saying that the wheel will just move up, down, and side to side, that means that the bolts that hold the column together have come loose. You will need to remove the wheel, turn signal switch, lock cylinder, tilt spring, and the 2 tilt piviots. Then get in there just past the ball joint on the steering shaft and tighten the 4 bolts down there, then reassemble. Might take you about 2-3 hours if you have never done steering column work before. HTH, Korey.
Old Feb 10, 2007 | 09:17 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
ORIGINAL: Kordog
EXCELLENT JOB! that's exactly the advice you should have received...now get to work
Old Feb 11, 2007 | 12:49 AM
thevair65's Avatar
yeah the wheel wobbles all over. it wont go any higher then the tilt wheel will allow. i already pulled most of that stuff because no matter the outcome i knew it had to go. thanks for the help.
ctyler
Aug 25, 2020 04:06 PM
litterbug
Oct 19, 2011 07:50 AM
Parilio
Sep 21, 2011 06:56 AM
caseroj
Oct 20, 2010 08:10 AM
KrazyKAZ
Jun 18, 2010 11:03 PM
