Surging Transmission
Old Jul 25, 2011 | 10:03 PM
TheBeastofPC's Avatar
TheBeastofPC is on a distinguished road
Default Surging Transmission
When going up a hill between 25-30 mph my automatic trans starts surging between 2nd and 3rd gear. Every other speed is fine on flat roadds and up hills with no other surging. However, my blazer does clunk occasionally when taking off from a fulll stop. Please advise.
Old Jul 25, 2011 | 10:09 PM
What transmission do you have, TH350 or TH400? Is the vacuum line connected to the vacuum modulator and is this connected to a ported vacuum source or a manifold vacuum source?
Old Jul 28, 2011 | 08:56 AM
Unfortunately I am not able to slide underneath the vehicle, but I do believe it is a TH400. I have no idea about the other questions you asked.
Old Jul 28, 2011 | 11:33 AM
They both use similar modulators. I would recommend a replacement, adjustable modulator (typically called the red stripe modulator since it has a red line painted on it).
The vacuum source for the modulator needs to go to the intake manifold. Some of the ports on the carb are called ported ports which means that they may not have vacuum at idle or low throttle angles. A ported source is not correct for the transmission modulator valve.
ssummers
Apr 24, 2008 01:19 PM
mojoala
Aug 14, 2007 09:38 PM
doublek
18
Feb 1, 2007 10:58 PM
wildboar
May 29, 2006 04:35 AM
93blazerman
May 5, 2006 03:36 PM
