Thermostat Gasket
Old Feb 17, 2010 | 05:02 AM
SWATPARAMEDIC's Avatar
SWATPARAMEDIC is on a distinguished road
Default Thermostat Gasket
'94 Full Size Blazer. Replaced the thermostat gasket and upper radiator hose and it's leaking some antifreeze either from the hose at the water inlet or at the inlet and the piece it bolts to. The part store gave me a rubber gasket and it looks like there may have been a fiber gasket on there. Anyone know for sure which gasket is the correct one, or both?
Old Feb 17, 2010 | 06:06 AM
Either should work, but there are some cases where, if a fiber gasket is used, the t-stat housing will pit, causing a leak when using the rubber gasket on the t-stat itself. I'd go back to the fiber gasket with some RTV for added assurance.
Old Feb 17, 2010 | 12:45 PM
abig84's Avatar
Agreed. Also can throw 2 hose clamps on that hose just to be sure
Old Feb 17, 2010 | 01:21 PM
Sounds good, thanks for the information. I'll try both.
limited edition 1
Jan 27, 2023 11:07 AM
J.R. Clay
Mar 17, 2011 08:22 PM
LJ809
Apr 25, 2010 06:02 AM
carterx
Jun 11, 2009 08:21 PM
01gmcjimmy
17
Jan 4, 2008 10:17 PM
