timing 454
Old Feb 28, 2010 | 08:18 PM
fatsjames's Avatar
fatsjames is on a distinguished road
Default timing 454
i have a stock(well looks and sounds pretty stock) 454 bb! its in my 78 chevy silverado! i was wondering if anyone knew what the ignition timing would be? is it the same as sbc?(350's) thanks
Old Feb 28, 2010 | 11:26 PM
mjchris's Avatar
mjchris is on a distinguished road
Default 454 timing mark
should be about 8 degrees btdc.
Old Mar 1, 2010 | 06:06 AM
I agree. 8* btdc #1. I typically tweak by ear though.
Old Mar 10, 2010 | 09:05 PM
Sadchevy's Avatar
Sadchevy is on a distinguished road
hook up a vacuum gauge....adjust timing for the highest vacuum reading ....then back off if pinging or detonation occur . works like a champ for my 502.
Old Mar 10, 2010 | 09:07 PM
I used a vac gauge on my 350 when I dropped the new HEI distributor in and it did a pretty good job of getting it close. I had to retard it a bit after the fact.
Old Mar 11, 2010 | 04:43 PM
fatsjames's Avatar
Default timing
i was going to ask how do you time it by ear! or how else it can be done! good info to have! thanks!
Old Mar 11, 2010 | 06:33 PM
Sadchevy's Avatar
by ear is easy ......you just listen to the rpms .....as you increase the advance rpms will increase until you get to far then it will run rough ......at that point back it off until you get a decent idle speed. this also goes in hand with adjusting your carb. as it will also change the rpms and vacuum ...which will affect timing .
Old Mar 12, 2010 | 09:11 PM
fatsjames's Avatar
Default timing by ear
thanks for the info! speaking of, i put in a different distributer, and it didn't line up like the other dist.(because the dist. was different) don't think i put wires in the right spot. so this made my timing marks off(i think) is this possible? now when i time it to 6* btdc, it doesn't run right, very low(rough) idle, so when i time it by ear, the time mark on the dampner is way off the scale! but it sounds and runs good! so to fix this problem? i would bring #1 piston to TDC, then re align my dist.? or maybe my spark plug wires? this poses a problem because the wires coming from the dist. don't reach far enough to advance timing any further!
Brewpubeaver
Feb 26, 2011 08:37 PM
PsychopathicD
Performance & Brainstorming
Jan 10, 2011 09:07 PM
mitchkup
Jul 26, 2009 08:22 PM
Greco
Mar 5, 2008 01:17 PM
