blazer 454
Old Jul 17, 2009 | 10:46 PM
mitchkup's Avatar
mitchkup is on a distinguished road
Default blazer 454
hi,
i am looking into buying a lifted 91 blazer with 35s. in has no motor but has a tranny with broken bellhousing (standard). it comes with a older 454 and auto tranny. i was wondering if the 454 would be good for a daily driver? i live in a small town so there wont be alot of driving around. is there much work swaping in a big block from a small block?
thanks
Old Jul 21, 2009 | 09:49 PM
bandidolenny's Avatar
The big block will fit right in. The factory throttle body fuel injection will not be enough for it though. You will either have to utilize a computer and injectors for a big block or use a carb... of course it won't pass an emissions test with a carb... But this is possible to do.
Old Jul 24, 2009 | 12:38 AM
mitchkup's Avatar
the 454 is from a older 1 ton and is tbi. what would be the easiest way in your opinion? how would the carb fit on?
Old Jul 26, 2009 | 08:22 PM
If you have the TBI along with the 454 then just plug it in and you are done. If not then get a set of 454 injectors and install them into your current throttle body.
Revelc
Nov 20, 2018 05:14 AM
Brewpubeaver
Feb 26, 2011 08:37 PM
PsychopathicD
Performance & Brainstorming
Jan 10, 2011 09:07 PM
Greco
Mar 5, 2008 01:17 PM
