transfercase question
Old May 5, 2010 | 09:36 PM
mjchris's Avatar
mjchris is on a distinguished road
Default transfercase question
i have a 79 k5 350turbo tranny it is full time 4wheel drive but has a sticker that says a part time conversion kit has been installed my question is that after the tranny shifts into 3rd gear and i let off the gas the truck bogs down like it needs a 4th gear or someting i am running the t-case in neutral and the front hubs are unlocked but this still happens am i running the t-case in the right gear or is this truck just geared that low i have no idea what the gearing is
Old May 5, 2010 | 09:44 PM
I doubt your problem has anything to do with the transfer case. You should be running it in HI range. HI-LOC should be used every once in awhile to engage the front output and lubricate the rest of the transfer case.
When you say it 'bogs down', does it just slow down rather quickly? How fast are you going when you let off the accelerator? How much does it slow down after a few seconds of coasting?
chris015
Dec 27, 2011 11:18 PM
tomdavis746
Jul 13, 2011 07:38 PM
broken_blazer
Apr 15, 2007 02:09 AM
broken_blazer
Apr 13, 2007 01:25 AM
napalm dan
Jan 13, 2007 08:55 PM
