Transmission Filler tube 72 blazer
Old Jul 9, 2013 | 08:40 AM
g-ronimo's Avatar
g-ronimo is on a distinguished road
Default Transmission Filler tube 72 blazer
My blazer is leaking tranny fluid like a hobo after a long night of drinking. The O-ring on the trans filler tube was replaced but I am wondering if the dipstick is not the right one. I think it may be too short, the tube might be too long, thus me adding WAY more than I should have. The gasket on the pan was replaced about 7 months ago.
How long should the dipstick be on a small block 350?
Further thoughts? Thank you in advance.
Old Jul 9, 2013 | 10:06 AM
70-K5's Avatar
70-K5 is on a distinguished road
Dipstick on the engine or transmission? Guessing your talking about the transmission...
Old Jul 9, 2013 | 10:43 AM
g-ronimo's Avatar
Default yes. transmission
on mine the transmission filler tube is all the way in the back of the engine. When I changed the o-ring on the tube, I kept checking the dipstick while adding a little more and nothing was registering after 2 quarts or so Then I finally got a reading. Does this make sense?
Old Jul 9, 2013 | 11:53 AM
70-K5's Avatar
The engine needs to be on and warm when checking the transmission level. Did you have it running?
Old Jul 9, 2013 | 12:14 PM
g-ronimo's Avatar
Thank you for your response.
uh...I think I ran it for about a minute or so. Should I wait for about 5?
Old Jul 9, 2013 | 02:05 PM
70-K5's Avatar
Should be up to operating temp.
Where is the leak coming from? is it coming from the dipstick tube? Did you double check that is is installed correctly, all the way seated?
Old Jul 12, 2013 | 11:40 PM
g-ronimo's Avatar
According to someone who looked at it, they said it might be the bolt near the filler tube. I am almost certain it was installed all the way seated then sealed around it. Someone said that the bolt needs to be tight but you can tighten it too much and then f up the something or the other. Still learning so sorry for the vagueness. Don't know the correct terminology.
stiggybaby
Mar 22, 2014 08:25 AM
kpfreeman2003
Jan 7, 2012 04:02 PM
chipjumper
Oct 27, 2010 09:31 AM
talonmike
Apr 27, 2009 11:00 PM
riceh8r0512
Sep 10, 2007 08:50 PM
