truck wont turn over
'79 K5...........will not start I have put fuel into the carb and still nothing so im going with no spark. I have already replaced the ignition mod. still nothing. I just drove it from california to kansas and once i arrived id did ok until one day it cut out on me while driving i parked it and it started right back up drove it to the store and when i got back in it would start or turn over. Any ideas as to what it could be. [&o]
Coil can be bad. Module is good option. Wiring inside the distributor is another. of course the most basic things have to work first. 1. Is there 12 volts at the coil? Seems I remember the fusible link on a 78 van giving me fits at the starter, this feeding the ignition ckt. Odds are most folks dont look there but thats where many come from. A greasy or dirty-loose connection or a broken wire or fusible link blown out or cut, can destroy the whole ckt. So trouble can certainly be AT STARTER, even if it turns over. This would be checked AT the coil ckt. Its the wire that is labelled BAT at the cap. Pull it off and check it when you turn on the key. 12 V positive when ignition is on.
Assuming this is good. Take the cap off. Is the rotor button (little black carbon thingy) and rotor, any good? Broken ones dont work. If things look good, remove the module and have it checked. It's cheaper than the coil. If it is good, make sure you get some fresh dielectric grease and reinstall the thing. Believe it or not, the capacitor actually does something and if it happens to be shorted, your car wont start. Those things are real cheap if you can find them. Always come with new module, do not replace module without new capacitor. Seldom happens though. That leaves the coil itself. Nothing else to check if you have given us correct info so far.
In other words, you said you had no spark.
Just read where you have already changed the module. I left the info anyway.
my 95 blazer wont start,this morning it ran fine but when i tried this afternone there was no power what so ever to the engine.this i the 3rd time this happens to me after aabout a day or a few hours it will turn on like nothing ever happend?
THePaRaSiTE5771
15
May 15, 2010 08:49 AM
trukin55
Apr 16, 2010 05:37 PM
hondacharger
21
Sep 23, 2009 01:25 PM
broke33
May 1, 2007 10:45 PM
