window problem
Old Mar 19, 2009 | 04:22 PM
BVFD25's Avatar
BVFD25 is an unknown quantity at this point
Default window problem
hey guys, I was wondering if any body knows where I can get the bolt that holds the window arm to the motor. mine broke or came loose some time back, and i'm tired of pulling the window up by hand. its not very secure either when you have a cd player, CB, and other stuff in it that you do not want to go missing! if nobody knows which bolt i'm talking about I'll snap a picture of it and get it on here. the thing is not really a bolt, (does not have threads on it) it has a flat top on it about the size of a quarter, in the middle it is about half that size, and at the end it is even smaller, but right at the end it is flared some what, and has cut marks on it, like from a hack saw blade, in the shape of a star. I do not know if this is original or if somebody has had this apart before.
Old Mar 19, 2009 | 05:41 PM
What might you be driving...? Are you talking about the manual crank handle or power?
Old Mar 20, 2009 | 08:40 PM
BVFD25's Avatar
sorry about that I Forgot to list that. its on my 85 K5 blazer, and it has power windows. its on the arm that hooks to the regulater on the window and the gear wheel, or what ever you want to call it, both have a hole in it and this bolt thing i'm talking about holds both together.
Old Mar 20, 2009 | 09:05 PM
Do you have a picture that you could post or could you take one and post it? Is this the tailgate window or a side window?
If it is a side door, I can take a look at the doors I have out at my dad's (came off of my 1990 suburban I am parting out) and snap a picture of how it is supposed to be.
Old Mar 23, 2009 | 10:33 AM
BVFD25's Avatar
ok thanks Swartlkk. yeah its the drivers side window, and I'll snap a couple of pictures of it today and try and get them on here today or tomorrow evening after work.
Old Mar 23, 2009 | 10:49 AM
Once I know what it is you are talking about, I can snap some pictures of the inside of my extra doors off the suburban next time I am down there (looking like Wednesday will be the next day).
Old Mar 29, 2009 | 09:34 PM
BVFD25's Avatar
hey sorry it took me so long to post these pictures, but my computer crashed and I just got it working again.
the first and second pictures are the bolt I was talking about.
the third is, the arm with the bolt in it.
the fourth is, the arm in place but without the bolt.
and the fifth is, the arm moved away from the gear wheel so you can see the other side.
hope this helps.
Attached Thumbnails window problem-dsci0775small.jpg   window problem-dsci0777small.jpg   window problem-dsci0794small.jpg   window problem-dsci0795small.jpg   window problem-dsci0796small.jpg
Old Mar 30, 2009 | 07:51 AM
What you have there is the original staked fastener. It is a rivet of sorts. It is not supposed to be off like that, obviously. If you have access to a welder, you can weld it back in. It is meant to be tight against the back supporting piece and give enough room for the arm to pivot. It should have a thin plastic washer under the face of it to keep down on noise.
Old Mar 30, 2009 | 07:04 PM
BVFD25's Avatar
ok so that means i cant just get a new one and put it on, because its something the factory did with a machine? as for the welder I do not have access to one. I'm thinking about just cutting a larger hole in the door and seeing if I can put a normal bolt in it, sense the door pad will cover it anyway. I'm guessing that would work as long as I can get a bolt that will be flush with the arm and the back of the gear wheel.
Old Mar 30, 2009 | 08:01 PM
The problem is that clearance may be an issue.
e602
91
Mar 8, 2015 04:53 PM
GolfClapperX
Jun 5, 2009 03:48 PM
Valafar
Mar 30, 2009 07:49 AM
hillbillyinOhio
Jul 12, 2006 04:18 AM
Chevy31104
Mar 15, 2005 12:10 AM
