wiring help!!
Old Oct 2, 2011 | 11:59 AM
litterbug's Avatar
Default wiring help!!
so yesterday i figured i would look at the wiring a little. i saw some loose wires that i soldered together by the starter. it was 2 wires going from the alternator. i connected them into one cause thats all that was there. so i start it up to see if there was any difference and i could not shut the damn thing off. i even disconnected the battery and still nothing. i had to bog the engine out by flooring it which choked the engine but now i have no idea where to go besides cutting the wires back to the way they were.
does anybody have a full wiring diagram of a 74 k5 or know where to find one? i have the service manual but this is very vauge when it comes to wiring.
i figured this thing is 37 years old so the wiring shouldnt be that complicated but i guess not....
Old Oct 9, 2011 | 10:27 PM
6.2 man's Avatar
6.2 man is on a distinguished road
On of those wires goes to the distributer for the points . The older starter systems had 2 wires on the solinoid one was for the ignition switch to energize the starter and there was another wire that hooked to another stud on the solenoid . When you would energize the starter it would also turn on this other wire to the points to make them hotter and start better when you hooked the wire up direct you kept juice going to the ignition system .I would un hook those wires the other wire could be an after market something another
Old Oct 10, 2011 | 11:50 AM
litterbug's Avatar
yeah. i just snipped them and its running how it should now. i even have lights and turn signals!!! this thing is really coming together!!!
Old Oct 10, 2011 | 02:59 PM
Z71_Guy's Avatar
Z71_Guy is on a distinguished road
some one could have converted it from points to an updated distributor
Old Oct 11, 2011 | 06:58 AM
litterbug's Avatar
it does have a HEI now. that could be it. either way it runs the way it is.
phxjosh
Oct 30, 2013 10:03 AM
speedhead
Mar 16, 2012 06:54 PM
nineteensixtycaddy
Sep 12, 2010 08:54 PM
The Franchise
May 31, 2006 12:28 AM
chris
Dec 6, 2004 12:47 AM
