02 Blazer 4X4 LS 4door
Old Nov 3, 2010 | 04:38 PM
Texas Mike's Avatar
Texas Mike is on a distinguished road
Default 02 Blazer 4X4 LS 4door
I have some dumb questions!!!!
I am trying to find what drivetrain I have. I know it has a 3.42 rearend, but what is it. 10 bolt 7.625 and what about the front axle? Ratio and brand? Transfer case, and transmission. It the front axle auto locking ??? Iknow it's an auto with overdrive, but which one?????
Also is it a common problem for the switches to go bad on the dashboard for the transfercase?
Old Nov 3, 2010 | 06:53 PM
A few quick searches will lead you to the information you seek!
Old Nov 6, 2010 | 01:48 PM
Project96's Avatar
Project96 is on a distinguished road
I'm here to seek the same info. Actually suprised that there isnt a spec thread on the main page. I have an 02 blazer ls & Im about to put the 2nd t-case in it in about 3 yrs. I was wondering if there were any upgrades to the internals that can be done to make it more reliable. Thanks.
Old Nov 6, 2010 | 10:09 PM
Rottidog's Avatar
Try http://www.compnine.com/vid.php & put your VIN in there. As for issues etc, just like Kyle said - search in here. There is tons of information when searching.
Old Nov 17, 2010 | 03:24 PM
Project96's Avatar
Is there a thread or sticky with the engine & drivetrain specs here? This is from another forum but used as an example. This is what im searching for.
What are the basic specs for the LT1?Block and Basics
Displacement: 350 cubic inches, 5733 cubic centimeters, 5.7 liters
Block Material: Cast Iron
Main Bearings: 2-Bolt Centers and Ends (The Corvette LT1/LT4 had 4-bolt mains)
Stroke: 3.48"
Bore: 4.00"
Compression Ratio: 10.4:1
Combustion Chambers: 54 cubic centimeters
Factory Redline Rating: 5700 Rotations Per Minute
Bottom End
Piston Material: (10159437) Eutectic Aluminum/Silicon Alloy
Connecting Rod Material: (10108688) Powdered Metal
Crankshaft Material: (12556307) Cast Iron
Top End and Valvetrain
Cylinder Heads: (10168448) Cast Aluminum, 2 valves per cylinder/16 valves total, ~212 CFM flow (Impala SS and Caprice heads were made of cast iron*) Valve Diameter: (intake- 10241743, exhaust- 12550909) 1.94 intake, 1.50 exhaust
Valve Overlap: 41*
Valvesprings: (10206040) 85 lbs, seated
Camshaft Specs (12551705): 205/207 duration @ 50*, .447/.459" lift, 117 Lobe Seperation Angle
Rocker Arms: (10089648) 1.5:1 Stamped Steel
Timing Chain: (10128485) Powdered metal butt link
ETC, ETC, ETC,...........
blazer206
Lowering Tech
38
Jan 15, 2011 11:19 AM
poeticviking
Nov 16, 2009 04:23 PM
dunontme
Jun 15, 2008 07:19 PM
FULLTHROTTLE
Nov 11, 2007 05:08 PM
BlazerBLS8
Headers, Intake, & Exhaust
Apr 13, 2006 04:07 PM
