1996 chevy blazer timing chain
Old Dec 29, 2012 | 04:22 AM
datsun147's Avatar
datsun147 is on a distinguished road
Question 1996 chevy blazer timing chain
Does anyone know what the labor cost should be for replacing the timing chain and gears on a 1996 blazer?
Old Dec 29, 2012 | 07:55 AM
chris015's Avatar
From a search,its about 7.8 hours for a 93. So,figure $60+/- labor,plus parts. Ouch...Why do you want to replace em?
Old Dec 29, 2012 | 08:41 AM
1996 is 7.8 warranty time, that's what GM pays the dealer when the vehicle is under warranty. Customer pay, (retail) shows 12.4 hours. Timing cover must also be replaced, and a crankshaft position sensor relearn performed afterwards. Again, why do you want to replace it? Chain problems are not common on the 4.3L engine.
Old Dec 30, 2012 | 08:07 PM
datsun147's Avatar
the engine will crank and spark but wont fire have changed the coil computer cam sensor so looked at chain it is real sloppy and loose loos as if it could be a tooth off or enough slop to cause no fire. shut it off 1 night next morn it was like this not my blazer so not sure of its history
Old Dec 30, 2012 | 08:33 PM
chris015's Avatar
what about fuel? check the pressure,with a real gauge. a "stick a knife in the nozzle to see if it shoots out gas" doesnt work on a blazer. they are touchy with required pressure.
Old Dec 31, 2012 | 07:08 AM
datsun147's Avatar
we have used starting fluid with no change, he told me pressure test was done but i didnt see it
drblaze
18
Jun 22, 2011 01:58 PM
shockley84
16
Dec 24, 2010 07:52 AM
gabenton
Mar 26, 2010 08:23 AM
dpannazzo
15
Dec 17, 2009 01:18 PM
2001blazer
Nov 10, 2006 12:48 AM
