1999 chevy s 10 blazer no brakes
Old Sep 19, 2022 | 02:04 AM
Hunter1989's Avatar
Hunter1989 is on a distinguished road
Default 1999 chevy s 10 blazer no brakes
I have a 1999 chevy blazer 4x4 with no brakes . It started out having the front brakes only . Didn't realize until I was going to put back brakes on they were not working . Checked all the lines and they are clear to the rear bled the front and now unless the key is off i have no pedal at all . I know the brake booster is working because fluid comes out of all four lines .
Old Sep 19, 2022 | 02:29 AM
How did you do the brake bleeding?
I finally got an OBD reader that also allows me to cycle the ABS system to help with the bleeding. In the past the best I could do was a gravity bleed. I'm planning on starting my fall maintenance on the truck in the next week or so and will by trying the ABS cycling for the first time.
Old Sep 19, 2022 | 02:33 AM
Hunter1989's Avatar
I just pumped the brake pedal until it was stiff and bled them through the bleeder vales . Was not aware you needed a reader .
Old Sep 19, 2022 | 02:51 AM
Here's what I think are all the pages from my 99 service manual on bleeding. (attached)
And, trying to get a hard pedal with these is notoriously annoying! So you are not alone.
File Type: pdf
Fozzy
Feb 11, 2015 09:45 PM
bigzimnh1
Feb 6, 2014 09:02 PM
m3ch
Aug 2, 2010 07:06 PM
kodie
Aug 13, 2009 02:36 PM
cool2drblazer
May 16, 2006 04:49 PM
