2000 Chevy blazer 4.3 4x4
Old Aug 6, 2022 | 06:58 PM
Kyleherron's Avatar
Kyleherron is on a distinguished road
Default 2000 Chevy blazer 4.3 4x4
So it was my daily driver and I bought a 89 c1500 and drove it for a week then went back to start the blazer and it was hard to start. It only hard to start in the mornings in the afternoons it starts right up. It would spit and sputter shift in between first and second and second and third. And when I hit overdrive lock up it would spit and sputter then I would lose lock up. but it’s been gradually getting worse to the point now it only backfires even when I use ether. If it does fires off it sounds low and boggy then nothing Only code it was thrown was for the crank sensor and I changed it. I have done this to it already
crank sensor
plugs
wires
cap and rotor
good fuel pressure
good spark
good fuel
fresh oil and filter
battery
I thought maybe the timing got off but sometimes it will fire up like nothing is wrong and the next day nothing I’m not sure
Any help is greatly appreciated in advance
Old Aug 9, 2022 | 09:15 PM
GeorgeLG's Avatar
Could be a lot of things. Do you have a scanner with live data capability?
Compare fuel pressure between running good and when its running crappy. Also monitor ignition voltage when it runs crappy.
George
Old Aug 11, 2022 | 08:36 PM
Kyleherron's Avatar
George
I don’t but my brother Is coming to look at it this weekend he’s bringing his scanner he’s a mechanic so I’m sure that his is capable and right now I can’t get it to run at all to test it at the moment
Nativewayz
40
Apr 21, 2020 01:38 PM
Spencer Grow
Nov 26, 2018 12:20 PM
jmoter35
Aug 23, 2015 09:47 PM
pensfan74
Sep 30, 2013 07:12 PM
fast400
Aug 31, 2007 05:07 PM
