2001 blazer 4.3l cold air, exhaust, programer
i own a 2001 blazer with the 4.3L, 4 door, 4x4. if i were to spend the money and install a cold air intake, get rid of the muffler and replace it with a glass pack or flowmaser muffler and possibly bought a programer..will i see a change for the better mpg and power wise? also which would be better a glasspack or flowmaster muffler?
To the OP, it all comes down to how you drive it. I doubt you'll see much by way of a performance/mileage gain by putting on a muffler, but it will sound different. On the muffler, it really comes down to what you want for a sound in terms of what to put on.
I'm sorry, but I hope you were kidding. There is NO way a CAI can make a truck running O2, MAF, MAP, & IAT sensors run lean. NONE. The stock PCM will adjust properly and do just fine at maintaining proper AFR. I have run a CAI on MANY vehicles with stock tuning and never had any indication of running lean on the plugs nor in the STFT/LTFT readings from the PCM.
If you don't care what anyone says, I guess I'm just beating my head against the wall trying to convince you, so I won't bother. But I can put the proper information out there for everyone else.
To the OP: you will see a gain from thoset hings combined, but again, as Kyle said, it all depends on your driving habbits. If you mash the gas all the time then you'll lose HP. I limit my RPMs to 2.5k in 1st, and 2k in all other gears. With a CAI and Hypertech tune currently set on 87 octane, I consistantly get 16 mpg. In the winter I'm probably going to get a mail order tune from Wait4Me or PCM4Less. As for the muffler choice, the glasspack is going to drone really bad at certain speeds. All depends on how much noise you're okay with.
ravenhurst
15
Apr 26, 2009 07:53 AM
dimmuborgir6nik6
Oct 2, 2008 06:51 AM
as2higpark
Oct 18, 2007 12:18 PM
