2wd at the boat ramp: requesting help
Old Jul 31, 2013 | 11:49 AM
impressive genitals's Avatar
impressive genitals is on a distinguished road
Default 2wd at the boat ramp: requesting help
Hello all.
I have a 2wd blazer. The only use I have for 4x4 is at the boat ramp. I really don't want to be "that guy" who gets stuck on the ramp.
Besides a full-on conversion, is there an alternative that can help me mimic 4x4 for this task only?
Some kind of slip differential or something (sorry I'm clueless)?
Thanks!
Old Jul 31, 2013 | 04:15 PM
rexazz2's Avatar
pick a boat ramp that's not so steep
I just pulled the boat out on Friday and never used 4wd
How big a boat is it ?
Old Jul 31, 2013 | 04:47 PM
cleburne red's Avatar
There are a few different choices of limited slips and automatic lockers available for the small 10 bolt our trucks have. You don't happen to have a G80, do you? That might do the job for ya.
Old Jul 31, 2013 | 05:07 PM
chris015's Avatar
Damn,cleburne beat me to it. If you have g80 (rear end locker system) You may not have any problems. Pop open your glovebox. Pull all your crap out lol and you'll see a sticker with a bunch of lil 3 character codes. Look for "G80". If its there you got it. it'll lock up both tires instead of one in a slipping situation. If not,You can always install a locker,or find a blazer rear end with g80 already and swap em out. (make sure its from a 2wd,and has the same gear ratio)
Old Jul 31, 2013 | 11:46 PM
Thogert's Avatar
Gear ratios don't need to match for a 2wd chris.
Old Aug 1, 2013 | 08:43 AM
Twip's Avatar
+1 ^
but that way it would drive the same and same fuel mileage. but if you do happen to go looking into switch rear ends and stuff, it could be a prime opportunity to change the ratio to something more suitable.
Old Aug 1, 2013 | 10:30 AM
chris015's Avatar
in a way it does,since if you make a change it'll knock the speedo off. So ha! lol.
Its not a drastic change,i went to 3:42 from some 2:73s in a old truck and i was like 6 mph off.
Karcinagin
Headers, Intake, & Exhaust
Jan 19, 2014 04:15 PM
Mag-300
16
Dec 29, 2011 07:30 PM
BlazerWare94
Jul 6, 2011 03:13 PM
beyondbasic
Aug 29, 2010 11:23 PM
kiwiblazer
Jan 19, 2010 09:37 AM
