3 step fuel cleaning service
Old Jan 19, 2014 | 08:29 PM
Bobcat13's Avatar
Bobcat13 is on a distinguished road
Default 3 step fuel cleaning service
Hey everyone, so I just had a 3 step fuel system cleaning service done on my s10 and man does that work wonders. Truck runs a whole lot better and smoother, and got about 3mpg! I strongly recommend all of you on here to go to a local shop and see if they offer it. You won't be disappointed.
Old Jan 19, 2014 | 08:42 PM
What year, model & engine do you have?
Old Jan 19, 2014 | 09:20 PM
Bobcat13's Avatar
97 s10 4.3L
Old Jan 19, 2014 | 09:23 PM
Have you done the injector upgrade to your engine? It eliminates the poppet valves, which like to clog up, and relocates the injectors to the intake ports. Plug & play, no programming necessary. Makes a noticeable difference in performance and mileage over the original injection system.
Old Jan 19, 2014 | 10:02 PM
Bobcat13's Avatar
Not yet. I will when the wallet permits...lol
Old Jan 19, 2014 | 11:39 PM
Rumblur's Avatar
Rumblur is on a distinguished road
Hook, I'm sure others would like to know this, but that intake upgrade - it's the whole intake and there up to the air cleaner, correct? And it's from years 2001 to 2004 only? Also, is there any MPG or HP increase or decrease?
Old Jan 20, 2014 | 02:37 PM
It's actually an injector upgrade, not intake.
1996 through 2002 originally came with this style of injector assembly:
It has 6 mini injectors in the metering block, and a poppet valve in each of the 6 nozzles. When an injector fires, it pressurizes the "spider line". The poppet valve requires ~43psi to open and squirt the fuel into the intake port. The problem is the poppet valve/nozzle tends to varnish up and either restrict fuel flow, stick open or stick closed. They usually end up dripping fuel into the intake port, instead of spraying it. That's when/why the injector cleaning becomes necessary.
2003 through 2005 came with this style of injector assembly:
On the upgraded injector assembly, the poppet valves were totally eliminated, and the 6 mini injectors were relocated to the intake ports. When the fuel pump is activated, all 6 "spider lines" are pressurized, right up to the nozzle of the injector. When the injector fires, the nozzle squirts fuel into the intake port, (no time lag waiting for the poppet to open).
The upgraded injector assembly can be installed on 1996 through 2002 4.3L engines with only one modification: A newly designed bracket to hold the new metering block in place. AC Delco and Delphi injector upgrades include the $20 bracket, most aftermarkets do not. Also needed, but not included, is an upper plenum gasket set. The upgrade is plug & play, no PCM programming necessary. Replacement time is under 2 hours.
After the upgrade, even with no problems in your old style injector assembly, you can expect better throttle response, performance, fuel mileage, and less of a chance of the nozzles getting varnished up in the future. The results are immediate.
FYI: If you're not sure if your engine has the upgrade, check the VIN. If the 8th character is a "W", you have the old style assembly, (unless it's been upgraded). If it's an "X", it has the upgrade from the factory.
Attached Thumbnails 3 step fuel cleaning service-96newercsfiinjectorwengine.gif
Old Jan 23, 2014 | 08:03 AM
12istheanswer's Avatar
12istheanswer is on a distinguished road
I am able to do most of the work myself on my blazer which is why I just bought it. After looking at my VIN I see that it has the W so now I am intrigued to do this upgrade. So that means I have two questions.
1. When looking to see if someone else may have done this upgrade already what do I look for?
2. How much $ for the upgraded system?
I have a 2001 Blazer LS with the 4.3L (4x4)
The reason I am looking into this is because I keep getting a fuel leak where the incoming/return lines connect on the top of the unit. If I am going to be replacing gaskets or such I might as well do the upgraded unit as well.
Old Jan 23, 2014 | 01:07 PM
JavierEscalonJr's Avatar
JavierEscalonJr is on a distinguished road
The spider cost me about 250 at pep boys, just don't do what I did and install everything and look for your rags I left inside the air intake holes. And I managed to use the same bracket as the old one struggled but I got it to fit
Old Jan 23, 2014 | 02:50 PM
Originally Posted by 12istheanswer
...I have two questions:
1. Remove the upper plenum and take a look. If it's been done, the injectors will be in plain sight. If you remove the plenum, don't reuse the gaskets. BWD Fuel Injector Seal Kit 11218: Purchase the best Fuel Injector Gaskets at Advance Auto Parts
2. Delphi part # is FJ10565, check around with Rock auto, Amazon, Ebay, etc.
If there is fuel leaking where the lines go into the injector assembly, you need one of these kits: Dorman - Help Fuel Injector O-Ring Seal Kit - GM 2005-96 90000: Search no more for the best Fuel Injector O-Ring Kit at Advance Auto Parts It has all of the O rings for the original style injector assembly, but you'll only need the ones for the lines. There is a certain order that the O rings and steel washers must be assembled in:
Attached Thumbnails 3 step fuel cleaning service-csfiupperintakemanifold.gif
NCRD1331
May 9, 2013 08:31 AM
chevyblazer9588
Nov 20, 2012 10:40 PM
poertsch
May 3, 2012 06:12 PM
rudd21
Nov 12, 2011 03:49 PM
toaks
Detailing
Aug 26, 2008 11:44 AM
