4WD shifter stuck
Old Nov 16, 2011 | 04:48 PM
89Recon's Avatar
89Recon is an unknown quantity at this point
Default 4WD shifter stuck
I went out today for a little bit of wheelin and I found out my shifter to switch to 4wd and 2wd doesn't work it is stuck in 2wd only any advice? could it just be from being so old? or what? opinions and help please.
Old Nov 16, 2011 | 06:15 PM
abig84's Avatar
when was the last time you used it? i bought a plow truck for parts and from the looks of it it was always in 4wd, i had to go underneath and spray the shift rails with penetrating oil and basically kick the shifter forward and backwards till it freed up. also if you have the truck in park too sometimes it wont shift
Old Nov 16, 2011 | 06:22 PM
xgiovannix12's Avatar
its gotta be on N for it to engage or disengage
Old Nov 16, 2011 | 06:23 PM
ChevyBlazerChick's Avatar
Yeah were you in Neutral when you were trying to shift? Also Mine takes some coaxing, I've got to shake it around while trying to shift.
Darnit Gio, I would have been before you but my pain in the patootie of a son distracted me for a couple seconds. lol
Old Nov 16, 2011 | 07:21 PM
89Recon's Avatar
that may have been the problem cbc and gio I was in park at the time I tried to shift it I am going out again tomorrow I will give it a try and see if it works then *here's hopin*
Old Nov 16, 2011 | 09:35 PM
You can call me Kayla instead of CBC if you want.
I made the same mistake when I first got my truck.
Also I still haven't figured out if you do in fact have to Put it in reverse after putting it in 4wd in order to lock it in. I do it anyway lol.
Old Nov 16, 2011 | 09:41 PM
never heard of putting it in reverse
I know some trucks you need to shut it off engage it in N then start it
Old Nov 16, 2011 | 10:03 PM
My dad told me... so I dunno if its true or not lol.
Or it may have been that I needed to back up to lock in my AutoHubs...
I dunno... but it doesn't hurt to do it anyway lol
Old Nov 16, 2011 | 10:07 PM
thats possible you might need to lock the auto hubs like that
I never owned a truck with auto hubs
Unless that new trailtruck i have (ford bronco) has them
I haven't picked it up yet
Old Nov 16, 2011 | 10:12 PM
lol, I upgraded to Manual Lockers and still did it just in case lol.
matthewp
Apr 4, 2021 09:16 PM
Glorf
May 20, 2012 08:05 AM
jasedude
Nov 24, 2010 04:03 PM
gmbwrenchn
Oct 28, 2010 07:30 PM
rbcar1
Dec 13, 2009 10:20 AM
