9.5" 14bolt
Old Feb 26, 2011 | 09:48 PM
Poh's Avatar
Poh
From: Berrien Springs, People's republic of Michiganistan, Socialist states of American
Poh is on a distinguished road
Default 9.5" 14bolt
can I get 5 lug axle shafts (In an S-10 Blazer pattern) for a 9.5" 14 bolt? I got a 6 lug one and I want to cut it down to fit under the Blazer. the stock 7.whatever just will not do
Old Feb 26, 2011 | 09:52 PM
You should be able to get custom axles made for it. If you have narrowed it, you're going to need custom axles anyway.
A 9.5" semi-floating 14-bolt is a bit overkill for an s-series truck though. The 8.5" diff found in the ZR2 and a few choice 5-speed 2-doors should be more than sufficient if you have experienced problems with the 7.625" axle.
Old Feb 26, 2011 | 10:59 PM
Poh's Avatar
Poh
I know its overkill thats why I want it, its also common as dirt and from what I can find the Zr2 axle is not common as dirt.
Getting a 5 lug shaft cut to fit is alot less expensive than getting custom 5 lug shafts made.
anyways I found my answer ........... the 454 SS trucks were 5 lug and semi float 14 bolt. those shafts are not as common as dirt and there is no aftermarket replacement. I can, however ger 6 lug shafts reconfigured to 5 lug (its what the 454 SS guys do) rather in-expensively.
Also looks like a 6 lug wheel bearing hub assy from a Silverado will bolt right in place of the 5 lug S-10 assy...... this will require more research and conversion to a 33 spline front CV axle..... the good news is, once the conversion is done it only needs to be done once and then I will be sporting over kill parts that are as common as dirt
and why do I want it ............ because I break stuff. when the 4l60e dies and I am out of warranty ...... I plan on a NV4500 and LS swap.
pmzusmc
Apr 19, 2011 05:44 PM
ComputerNerdBD
Feb 28, 2010 11:30 AM
volfan4
Nov 28, 2009 08:04 PM
midnightmekanik
Oct 8, 2009 08:32 PM
cide
Mar 23, 2009 10:57 AM
