92 k 1500 blazer overheating
Old Feb 18, 2022 | 02:17 PM
Line8014's Avatar
Line8014 is on a distinguished road
Default 92 k 1500 blazer overheating
Was running fine till after the last storm the radiator end cracked and leaking changed radiator now still overheating at idle just changed thermostat thought stuck closed top radiator hose cold in spots warm in others still overheating at idle changed in past water pump and two heat sensors what am I missing
Old Feb 18, 2022 | 07:47 PM
GeorgeLG's Avatar
This can be caused by air in the system. Make sure that the system is properly bled, I can give you guidance on the if you need it.
A plugged heater core or hose can be the cause of this. Take the hoses off of the core and flush it with MODERATE garden hose pressure in both directions then bleed the system again. Are both heater hoses the same temp?
George
Old Feb 19, 2022 | 07:21 AM
Line8014's Avatar
Was thinking air block in heater core I did not check hoses for temperature
Old Feb 19, 2022 | 12:32 PM
Line8014's Avatar
Must have been something in heater core ran hose backwards till clear then forwards also did both hoses till I saw movement in radiator works fine now thanks
Old Feb 19, 2022 | 12:36 PM
GeorgeLG's Avatar
Excellent, glad your fixed up.
George
Old Mar 20, 2022 | 08:03 AM
Line8014's Avatar
Default 1992 K1500 Blazer 350 engine
Earlier I replaced a bad radiator I changed the thermostat and it still overheated I flushed heater core because it was overheating and the truck ran fine now it is overheating again all hoses are equally super hot
Old Mar 20, 2022 | 09:01 AM
GeorgeLG's Avatar
Are you sure that you got it completely bled and there is no air at the top of the system. Mine always requires some extra effort to get right.
George
Old Mar 20, 2022 | 09:56 AM
Line8014's Avatar
I am going to fill while running again see if there is still air in there.
Old Mar 20, 2022 | 11:59 AM
GeorgeLG's Avatar
Try to get the front of the truck elevated like in a sloped driveway, increase rpm and consider some type of fill funnel arrangement that gets the fluid level above the cap. I use one of these:
Amazon Amazon
I see some cheaper knock offs as well.
If this does not solve your problem then we can go further with things like: belts, water pump, head gasket, dash gauge, wiring, ...
George
Old Apr 28, 2022 | 10:53 AM
jimspahr@msn.com's Avatar
That funnel arrangement is designed to get the air in the system released so it 'burps itself'. Chris Fix in one of his radiator fill video's shows this type funnel in use and how it does its job. You attatch the funnel to the rad., fill it with coolant, and then run the engine for 15 min.s or so.
The thermostat should be open durnig this procedure. The engine's cooling system releases the air through the funnel. You will see the air bubbles in the funnel. The elevated funnel becomes the highest point in the cooling system...... Higher than the heater core. This allows all the air to be bled out of the system.
karlb
15
Jun 4, 2016 09:21 PM
NohaDwalt
Aug 21, 2014 01:35 AM
njval1
Aug 2, 2011 07:33 AM
afrench690
15
Apr 17, 2008 05:46 PM
PawNtheSandman
May 2, 2005 11:15 PM
