93 needing some brighter lights
Old Feb 6, 2009 | 04:12 AM
brosko's Avatar
brosko is an unknown quantity at this point
Default 93 needing some brighter lights
hey im getting a 93 blazer and i know im going to want some brighter lights what do you guys recomend i do ?
i also have a 97 s-10 that could use a lot better lights too thanks BF
Old Feb 6, 2009 | 01:50 PM
bammontana's Avatar
bammontana has a little shameless behavior in the past
Default RE: 93 needing some brighter lights
Mount 4 driving lights on top and 2 on the bumper!!!
Old Feb 7, 2009 | 01:35 AM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
id say the best bet would be silverstars or HIDs
Old Feb 7, 2009 | 07:20 AM
bammontana's Avatar
If you are doing HIDs, you should look into a projector setup as HIDs + factory headlight assem = glare for other drivers
Old Feb 7, 2009 | 08:07 AM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
93 is a bit more difficult than the later years due to the craptastic sealed beams but there is hope check out This Link I strongly suggest the harness directly under the new light fixture (new fixture allows just changing the bulb instead of the entire unit) for a little more oomph in the power to your lights (these 2 things are pretty much essential if you plan on a hid conversion) another option (way cheaper) that I just seen the other day at pep boys is the silverstar sealed beam lights that are a direct replacement for your o.e. lights (dont know anybody who has used these yet so I cannot offer any info on how bright they are other than 5000k according to the packaging)
xJakeLIKEShisBLAZERx
Feb 11, 2018 07:00 PM
Nick101
Feb 10, 2015 06:29 PM
cimbaliw
Nov 2, 2012 07:27 AM
DaddysBlazer
Oct 1, 2011 12:58 PM
blazerboy124
Apr 22, 2008 11:43 PM
