97 Blazer TCCM location
Old Dec 7, 2019 | 12:01 PM
WolfPack1's Avatar
WolfPack1 is on a distinguished road
Default 97 Blazer TCCM location
Hey everyone! My 4x4 is unresponsive. There are no lights, no clicking, nothing. I did a bunch of searching to find where my TCCM is, and I haven’t had any luck. It is not under the passenger side kick panel, and I have attached pictures. Any idea on where it could be? Or what would make my 4x4 unresponsive at all?
the only thing I found was the air bag module.
Old Dec 7, 2019 | 12:36 PM
bravo99's Avatar
there should also be a 4 by 4 fuse in the driver instrument panel fuse box if that is blown your tccm probably took it out. another related thread mentioned the passenger pillar instead of kick panel but I don't know if they were trying to refer to the same spot. the pillar (Dash to roof) seems not wide enough for a tccm to be hidden behind. If it's a four-door and their meaning the center pillar check the wide space between the two doors.
Old Dec 7, 2019 | 01:26 PM
WolfPack1's Avatar
Thank you for the info! I actually just pulled the dash and found it. It ended up being like the 95-96 where it’s in the center under the dash behind the cigarette lighter. I have checked the fuse in the driver door/dash area and it looks good. Are there any other fuses? Not sure where to go on it now. Do you think it’s worth getting a new three button selector switch and trying that? I do need to replace the vacuum lines under the hood, but I thought it should at least light up or try and engage if it was only the vacuum lines.
Old Dec 7, 2019 | 01:54 PM
bravo99's Avatar
my Bravada has a separate automatic transfer case fuse in the engine bay fuse box but you don't have that Tcase so I don't think you would have that fuse live. Im limited how I can help cuz I also don't have any buttons... have you ever seen your 4 by 4 dash light come on?
Horton
Apr 26, 2013 12:05 AM
ahumann
Feb 21, 2011 07:00 PM
01blueblaze
Oct 16, 2010 01:39 PM
vrryder
Dec 29, 2009 11:34 AM
Browndog
Aug 16, 2009 01:14 PM
